Activity Forums Maxon Cinema 4D How to create low polygon model?
  • How to create low polygon model?
    Posted by Yoshiko Tanaka on August 6, 2014 at 11:32 am
    Hello,
    I am a newbie to Cinema 4D. I am making models for a sculptor to make objects. He will be using PVC to construct the object and lower the polygons are easier/faster/cheaper it is for him to make.
    I figured a way to lower polygons by reducing the “Subdivisions” but that seems to only work with the basic shapes like cube, box etc but I can’t figure out how to do that with the custom made model. Attached is one of the shapes that I created.
    Please help, thank you!
    y
    Brian Jones replied 12 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    August 6, 2014 at 5:08 pm
    that shape can be made from the Oil Tank primitive but for more complex stuff you could try the Polygon Reduction Deformer but it’s output is probably not what you want – otherwise you have to plan it and build it from the start
