Activity › Forums › Adobe After Effects › how to create Logo to sand to new logo to sand etc
Posted by Tyler O’banion on May 26, 2010 at 3:58 pmI want to create a logo to sand to logo to sand etc etc but i can’t figure out how to do it but the main issue is making it seamless where the logo getting blown away also starts creating the new logo any help would be great.
John Cuevas replied 16 years, 4 months ago 4 Members · 6 Replies -
Walter Soyka
May 26, 2010 at 4:44 pmI’d use separate particle systems for each logo. Make sure your emitter and physics settings match, and have the second system start up as the first system winds down.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Michael Szalapski
May 26, 2010 at 5:48 pmYou have Trapcode Form and Particular? Great. Those are both good systems to use.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Walter Soyka
May 26, 2010 at 6:10 pmWhen I said “separate particle systems,” I meant separate instances of whatever particle system you’re using.
For example, if you’re using Form, build out the logo-to-sand animation. Then, create a new Form layer, and build a separate sand-to-logo animation. Overlap them so that as the first logo-to-sand animation is blowing away, the second sand-to-logo animation is blowing in.
Walter Soyka
John Cuevas
May 26, 2010 at 7:56 pmThis tutorial should give you a pretty good start:
•Episode 21: Creating a Text to Sand Transition
https://www.redgiantsoftware.com/videos/tutorials/#trapcode-formJohnny Cuevas, Editor
http://www.ckandco.net
