Activity › Forums › Adobe After Effects › How to create gold text???
Posted by Dotan Baytman on April 26, 2007 at 5:46 pmIs it possible to create gold text in AE like in photoshop or like the gold in invigorator?
Dotan Baytman replied 19 years, 4 months ago 2 Members · 3 Replies -
Mike Clasby
April 26, 2007 at 6:20 pmGEMs has an AE Gold Texture freebie, here:
2. broadcastGEMs_Lower3rd TexTures (Gold & Plastic)(AEP ver 5.5+) (8kb)
https://www.broadcastgems.com/download/
OK, I checked these our and it’d good. All you need to do is open the comp “Golden Lower 3rd” then E reveals the effects, select them all, then Animation>Save Animation Preset. You will then have a gold preset to drop on any text.
Note: The Bevel Alpha doesn’t like some text, like Impact, M’s and K’s so you might need a text without those sharp intersection, you’ll see what I mean.
Enjoy.
Mike Clasby
April 26, 2007 at 6:22 pmYikes! I forgot to add, don’t select the mask when you make your preset as then it will be in the preset, effects only will do it.
Dotan Baytman
April 26, 2007 at 7:31 pmThanx for the tip saave me some work in photoshop and use the image file as text
p.s if you select all the effects how you can select the mask aswell?
