Activity Forums Adobe After Effects how to create feather around text in CS4
  • how to create feather around text in CS4
    Posted by Samya Chattopadhyay on April 11, 2012 at 7:10 pm
    Hello there…
    I have a problem…may sound silly though.
    I want to create simple feathers say black around the text. Actually I need to write something on a video layer which naturally has different tones in different parts.
    So I need to create the feather to make the text…say white or creame yellow…legible.
    Anyone…please help…
    Sam
    John Cuevas replied 14 years, 4 months ago 3 Members · 4 Replies
  • Ryan Hill
    April 11, 2012 at 8:36 pm
    I might duplicate the text layer, change one to yellow and add a blur filter.
  • John Cuevas
    April 11, 2012 at 8:41 pm
    Assuming you have the video in AE, you would create your text on one layer. Add a solid(cntl+y) and place that behind the text and use the mask tool to make it the size you need. Press MM and you can access the feather properties of the mask.
    What you are trying to do is pretty basic, which leads me to believe you are just getting starting out with After Effects. You might want to check out this page(Todd Kopriva of After Effects compiled which has links to a lot resources and tutorials that will help when first learning this program.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Samya Chattopadhyay
    April 12, 2012 at 4:47 am
    A big hello and thanks…
    Yes you are right…I am a newbie to AECS4. I tried a bit different.
    Instead of creating the mask, I duplicated the text layer, then created a shape from that text and then applied Fast blur.
    Last, I took the text layer over the shape layer.
    I would render it without the solid underneath and will take alpha. Hope that will work.
    Here is a snap what I came up with.
    Again thanks for both of your replies.
    Sam
  • John Cuevas
    April 12, 2012 at 11:44 am
    Glad you were able to work it out. You discovered one of the best things about AE, there are multiple solutions to almost any problem.
    Thinkck.com
