Activity › Forums › Adobe Illustrator › How to create DNA graphic?
  • Vincent Rosati
    June 8, 2010 at 3:46 pm
    Helix 2
    Helix 3
    These show all of the techniques you will need.
    However since the waves are repeating pattern, you could probably start with a straight path and apply Effect/Distort…/Zig-Zag, Smooth…
    After you Object/Path/Outline Stroke the shaped path, you could offset a copy of the expanded shape and use Pathfinder/Subtract Back to create the lighter colored/front shapes to create the shading.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
