How to create depth on a texture
OK… so I’ve got this:
Basically it is a sphere with an alpha map and texture. However, I want the thing to look more like pipes or strings rather than the ribbon-like result you see.
Is there a way other than drawing splines, using sweep nurbs, and wrapping them around a sphere? (And tips on doing it that way would be appreciated 🙂 )
Joe
