Activity › Forums › Adobe Encore DVD › how to create cube menu transition
  • how to create cube menu transition
    Posted by Jack Laurie on October 27, 2005 at 8:22 pm
    If not with encore, is there another program that can make a menu rotate like a cube to the next submenu selected? (winxp)
    thanks.
    Jack
    David Garrett replied 20 years, 11 months ago 3 Members · 3 Replies
  • Tim Kurkoski
    October 28, 2005 at 2:52 pm
    Premiere Pro has some basic cube-style transitions, though they’re not very fancy. I’m aware that third-party effect and plug-in packages have cube options, but I couldn’t give you any names. After Effects could do it also, of course, but you’d need to set it up manually.
  • Jack Laurie
    October 28, 2005 at 4:58 pm
    Thanks. So basically clicking the button to a new menu plays the made movie of one menu transitioning to the next and then the end action is to leave you at the new menu. Is that the correct process? If so is there some settings that will make the movie end and the next menu appear seamless?
  • David Garrett
    October 28, 2005 at 5:16 pm
    I’m afraid that Encore don’t do “seamless” , but going from menu to menu makes things a little faster to the eye, rather than going from menu to timeline where there is a noticeable gap.
