Activity Forums Adobe After Effects How to create a very large 3D floor area?
  • How to create a very large 3D floor area?
    Posted by Georgina Lord on July 25, 2012 at 2:58 pm
    I have a composition that calls for a very wide and very long floor that fades off into the background.
    I created a new 3D solid and in the initial dialog box I put 15,000 x 15,000 pixels for the solid size. Of course, I quickly found out that after applying a few effects, AE gave me a “out of memory” message. Obviously creating solids that large isn’t the way to go.
    Is there a more practical way to create an extra large floor area?
    Robert Headrick replied 14 years, 1 month ago 3 Members · 2 Replies
  • Kevin Camp
    July 25, 2012 at 5:31 pm
    tiling the floor can often help. for instance, rather than 1 15k x 15k solid, you could try 15 1k x 15k solids placed edge to edge.
    there may also be ways to fake it, depending on camera movements and how the floor is.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Robert Headrick
    August 3, 2012 at 7:44 pm
    You might also try tiling with an effect, though I’m not sure off the top of my head if that will help or hurt the processing requirements of your comp. Create a smaller solid to start with and use CC Repetile to extend the edges as far as you need them to go, and see if that works any better.
