Activity Forums VEGAS Pro How to Create a Soft Edged Iris Tranition Vegas 16?
  • How to Create a Soft Edged Iris Tranition Vegas 16?
    Posted by Dave Croonprince on May 18, 2020 at 12:08 am
    Hi – I’m having an issue creating a soft edged iris in/out transition on Vegas 16. I don’t want any kind of border on it or any kind of 3D bubble look. I just want to feather the edges so it is very soft. Not sure where to adjust this. Thanks for your help.
    Dimitrios Papadimitriou replied 6 years, 3 months ago 3 Members · 2 Replies
  • Graham Bernard
    May 18, 2020 at 5:41 am
    [dave croonprince] ” Not sure where to adjust this.”
    Hi Dave! – I don’t see a place in that Transition to do this – pity . . . However, do you fancy this?
    Before Transition:
    Start Transition:
    During Transition:
    Finish Transtion:
    I don’t see anywhere in that Iris Tran to soften the Edge? This was most likely Modelled on the Camera Iris, and as such, a soft edge was kinda not required. Now, there maybe be OTHER Transitions that do – 3rd Party, etc.
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Dimitrios Papadimitriou
    May 18, 2020 at 4:57 pm
    You could do this manually with the circle masking tool, if you want it to be centered it would be easier to do it with the cookie cutter, just make sure you turn up feather.
