Activity › Forums › Maxon Cinema 4D › How to create a soccer goal net
  • How to create a soccer goal net
    Posted by Joseph M. morgan on July 18, 2007 at 3:24 pm
    Anyone have an idea how to create something like a soccer goal net? I could quickly create a couple of splines (the net is just a bunch of hexagons, half hexagons on the edges), sweep nurb them at a very tiny scale… then duplicate as instances until I have something the correct size… but then it wouldn’t be flexible. Right now, I don’t need to animate it, such as blowing in the wind or being hit by a ball, however, it might get to that.
    I’m wondering how to wrap it on a goal when done… Is shrink wrap the way to go>
    Ideas very welcome…
    Joe
    Adam Trachtenberg replied 19 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • Randy Johnson
    July 18, 2007 at 3:47 pm
    hmmm…i am not to experianced with this but i would try making the mesh with plane (plenty of polys) and an atom array then use the cloth tag to make it hang, react and such.
    good luck
  • Adam Trachtenberg
    July 18, 2007 at 11:00 pm
    Personally I would just use an alpha mapped texture on a plane unless there’s some kind of extreme closeup.
  • Alejandro Torres
    July 19, 2007 at 2:31 pm
    Why don’t use the suggested alpha and if you want to animate something try the cloth module?
  • Joseph M. morgan
    July 19, 2007 at 4:11 pm
    So… will there by any depth to the net other than possibly a bump map of nylon rope in a mixed texture?
    What I’m getting at is… if we do get close, or at a 90% angle, will it disappear?
    Joe
  • Adam Trachtenberg
    July 22, 2007 at 3:36 pm
    You could use subpoly displacement in the material to create some depth.
  • Adam Trachtenberg
    July 22, 2007 at 3:59 pm
    [Adam Trachtenberg] “You could use subpoly displacement in the material to create some depth.”
    Thinking more on it, as long as the plane isn’t board-straight, e.g., you use Clothilde or some kind of deformer on it, you shouldn’t have a problem with it disappearing from the side.
  • Joseph M. morgan
    July 22, 2007 at 6:08 pm
    So if I deform the plane in the same way as a net would normally sag under gravity, this should work, right?
    Is Clothilde and Cloth module the same thing?
    I’ve never used either… nor a sub-poly displacement as best as I know… so, in the interest of learning, I’ll look into them both.
    Joe
  • Joseph M. morgan
    July 22, 2007 at 6:10 pm
    Looks like this is the way to go…
    Thanks.
    Joe
  • Adam Trachtenberg
    July 22, 2007 at 10:29 pm
    Hi Joe,
    Yes, Clothilde and Cloth module are one and the same. Sagging the plane will work fine as long as you are using UVW mapping for the material along with a stick texture tag.
