Activity Forums Adobe After Effects how to create a random opacity for triangle BG
  • how to create a random opacity for triangle BG
    Posted by Manish Choudhary on August 11, 2018 at 11:20 am
    i have a project were client need random opacity in its BG
    any suggestion how to create it in AE
    i created pattern what client needs but now how to animate it.
    video has to be like mentioned link
    ref.
    https://youtu.be/NZrvSqJYTZM
    Steve Bentley replied 8 years ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    August 11, 2018 at 4:19 pm
    Using this free stock video does not work because … ?
    Senior Graphic Designer
  • Steve Bentley
    August 11, 2018 at 5:19 pm
    You can use the wiggle expression on the transparency attribute. Use a long period (time between “changes”) and you may have to set min and max of 0 and 100. You may also have to round off the result as opacity only takes positive integers.
