Activity Forums Adobe After Effects How to create a perfect running loop?
  • How to create a perfect running loop?
    Posted by John Davis on December 22, 2015 at 1:21 am
    I’ve filmed an actress running in place in profile against a greenscreen. I’ve been looking all over for a tutorial that will show me how to loop the footage perfectly. Does anyone know how to do this? I’ve played with the mesh tool, but it’s not giving me the best results.
    Thanks for reading!
    John Davis replied 10 years, 9 months ago 3 Members · 4 Replies
  • Ivan Myles
    December 22, 2015 at 1:54 am
    For a perfect match you would need to reverse the footage to end on the first frame. Would that work for your application, or are you looking for a solution that interpolates new frames to wrap around from the last frame to the first frame?
  • John Davis
    December 22, 2015 at 2:06 am
    I’ve been reversing most of the actresses’ other movements, but with running that isn’t possible. After she’s been chroma keyed, I’m using a lot of filters that turn her into a blurry painting. So I think I’m looking for something that will allows me to distort the last frame into looking like the first for a perfect loop. This usually wouldn’t look natural, but since the figure is basically a cartoon character I don’t think it will be noticeable.
    I’ve lined things up so the first and last frames are almost identical, but besides the puppet or mesh tool I don’t know of a way to bend the figure into the perfect position. Hope that makes sense.
  • Walter Soyka
    December 22, 2015 at 3:11 pm
    [Samuel McClure] “I’ve lined things up so the first and last frames are almost identical, but besides the puppet or mesh tool I don’t know of a way to bend the figure into the perfect position. Hope that makes sense.
    I like RE:Vision Effects RE:Flex [link].
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • John Davis
    December 22, 2015 at 6:42 pm
    Thank you, that’s perfect! I’m using their other plugins already, they’re excellent.
