Activity Forums Adobe After Effects Expressions How to create a more realistic and smoother swing ?
  • How to create a more realistic and smoother swing ?
    Posted by Jack Goux on February 23, 2017 at 10:58 am
    Hello there !
    I am working on a little animation where i want to make a chair swing a bit on the side then replace normaly, but i don’t like the look of it.
    It’s not natural and not as smooth as i would like it to be.
    The problem is that i don’t really know if it’s the movement itself that is weird or just the chain of sequences that makes it look weird as before swinging on the side, there is a kind of zoom out effect starting from the center of the chair, so it would be more natural that the swing movement goes backward (which i can’t do because the chair is not in 3D)
    if someone can help me or give me advices on what to do i’ll appreciate. Note that i didn’t use expressions, just key frames hand by hand…
    Here is a gif to make it more clear : https://gph.is/2lt7JJ4
    Rob Womack replied 9 years, 6 months ago 2 Members · 1 Reply
