Activity Forums Adobe After Effects How to create a master comp with different multiple comps
  • How to create a master comp with different multiple comps
    Posted by Samik Pal on September 11, 2020 at 12:04 am
    Hello experts,
    I have newly started using after effects and I am trying to create a compositions which would contain multiple compositions. I can’t seem to figure out how to do that.
    To elaborate, let’s suppose I have made four different aep projects (eg. Anim1, Anim2, Anim3, Anim4) of same width and height 1280×720 px and 30 fps each 3 seconds in long. Each of them contains keyframe animations.
    Now I have created a separate comp (e.g. master) of 1280 x 720 px containing 4 grids of 320×180 px each 30 fps and 3 seconds in duration.
    I desire to bring in all 4 projects into master and resize them to the grid so that it looks like all 4 animations are visible from one single composition.
    Is it possible in after effects? How do I split separate comps into the desired grid length,height and position?
    If someone can please point me to the correct direction would be great.
    Thank you in advance.
    Hope Holmesby replied 6 years ago 3 Members · 5 Replies
  • Hope Holmesby
    September 11, 2020 at 6:46 pm
    render all animations 1-4, import into master project, they will be 4 layers in the one comp. resize them to be the desired format : like this one would guess from the description
  • Brendon Murphy
    September 11, 2020 at 8:18 pm
    Drag all 4 precomps into the master comp. With snapping enabled, use the pan-behind tool (y key) to drag each layer’s anchor point to a different corner of the comp. Scale all layers to 50%. Here’s the end result:
  • Hope Holmesby
    September 11, 2020 at 11:24 pm
    hi Brendon
    why do you put the anchor point at the corners of each like above?
  • Brendon Murphy
    September 12, 2020 at 4:56 am
    It’s a quick way to make sure the precomps land in the exact right place without needing to tweak the position.
  • Hope Holmesby
    September 12, 2020 at 6:51 pm
    ok, so you just drag them in and the anchor point makes it go to that place…nice…
    oh, because you have snapping enabled…ok…smart, thank you.
