Activity › Forums › Adobe After Effects › How to create a map projection for CC Sphere Mapping
Posted by David Fuchs on February 2, 2012 at 4:57 pmI’ve got a vector graphic I need to distort so that once I wrap it via CC Sphere plugin, it won’t appear distorted–probably using the equirectangular projection (https://en.wikipedia.org/wiki/Equirectangular_projection). Anyone have ideas? I’ve found similar questions on the forum but many link away to a raster image tutorial which would simply not work–I need crisp vectors for the lines.
Mato Kokotic replied 14 years, 7 months ago 4 Members · 9 Replies -
Michael Szalapski
February 2, 2012 at 5:20 pmCC Sphere will not continuously rasterize vector lines. It will need to be a high resolution rasterized graphic.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
David Fuchs
February 2, 2012 at 5:37 pmFair enough, I’ll have to make it raster. The issue with creating a projection still stands, though.
Michael Szalapski
February 2, 2012 at 6:44 pmYou mentioned that you had already found some tutorials and, since you’ll be using a raster image after all, I figured you were already set. What tutorials have you found and what about them isn’t working for you?
– The Great Szalam
David Fuchs
February 2, 2012 at 7:58 pmAh, sorry. The tutorial that Cow forumgoers have linked is https://www.maxoncomputer.com/tutorial_detail.asp?tutorialID=54
But that won’t fly for line art.
David Fuchs
February 2, 2012 at 11:04 pmUnfortunately those don’t really help. This isn’t a map.
Here’s the base design:
https://i.imgur.com/qEVDE.pngHere’s what it looks like thrown onto CC Sphere:
It’s obviously fine around the center, but towards the edges it becomes warped. Any attempt to manually distort it by trial-and-error seems exercise in futility (tried lens distortions, mesh warps, etc.)
Jens Enqvist
February 3, 2012 at 7:13 amYou could take a look at our CFX Sphere Utilities, especially Mappit although it might be difficult if your art covers a large portion of the sphere. Perhaps adding the elements one by one would work. Anyhow, take a look.
Mato Kokotic
February 3, 2012 at 8:55 amLet’s try a different approach:
In Photoshop make square image of desired map.
ThenFilter>Distort>Spherize -100% (minus)
and save new map.
In AE make comp with double horizontal size of your map (height stays same), import your map on timeline, double its horizontal size too,then apply
Effect>Distort>Polar Coordinates – Polar to Rect 100%
Adjust vertical position and vertical scale as desired and add a solid beneath to fill the gap. Precompose. Use this composition as a map for CC Sphere. Rotate on x axis 90 and that’s it.
3626_equirectangularmap.rar.zip
Example is lowres, png was small
David Fuchs
February 3, 2012 at 1:35 pmTried that as well, as at least as far as I can tell it wasn’t suitable for something you were trying to wrap around the sphere–it just tried to make the design “orbit” it instead.
Mato Kokotic
February 3, 2012 at 3:06 pmI don’t get what do you mean. In attached projedt it WAS mapped on a sphere (on the HALF of sphere (hemisphere?)).
Isn’t that what you want to achieve?
Have you tried attached project?
