Activity Forums Maxon Cinema 4D How to create a “bendable” spot light
  • How to create a “bendable” spot light
    Posted by Joseph Tam on February 8, 2014 at 10:17 am
    I would like to create a spot light beam that can be bent and animated; I believe this is impossible to do just by using the regular “spot light”, therefore I tried using a cylindrical tube (via Sweep Nurb with splines) and then applying an area light onto the object with glow enabled in the render settings.
    The resulting look was not satisfactory — I could not get the sort of diffused / volumetric light one would see from a real spot light.
    Does anyone have any idea how I could achieve the desired look? Any help would be greatly appreciated!
    Ronny Traufeller replied 12 years, 7 months ago 2 Members · 1 Reply
  • Ronny Traufeller
    February 12, 2014 at 8:13 pm
    mmhhh
    i would stick to the tube, and then
    using a texture with illumination and
    transparancy for it, maybe turn on
    the additive function in the material.
    ron
    traufeller.de
