Activity › Forums › Adobe After Effects › How to create a 15-minute countdown in After Effects?
Posted by Thomas Reimer on July 6, 2015 at 6:37 pmHi there,
I’m fairly new to after effects, and I can’t seem to find a tutorial online to help me create a 15 minute countdown timer in after effects. Any help would be appreciated.
Thomas
Walter Soyka replied 5 years ago 5 Members · 6 Replies -
John Cuevas
July 6, 2015 at 8:16 pmI did a search in the expressions forum and found this countdown timer. Just create a comp 15 minute long. Press “cntl+alt+shift+T” to create a text layer. Copy the entire expression written below. Twirl open the text and “alt + click” the source text stop watch to enable expressions, then paste expression below into the box. Lastly, make sure the text is right justified.
rate = -1;
clockStart = 900;function padZero(n){
if (n < 10) return "0" + n else return "" + n } clockTime = Math.max(clockStart + rate*(time - inPoint),0); t = Math.floor(clockTime); min = Math.floor((t%3600)/60); sec = Math.floor(t%60); min + ":" + padZero(sec)Johnny Cuevas, Editor
ThinkCK"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb. -
Thomas Reimer
July 7, 2015 at 12:19 pmThank you so much! I have been searching for this expression but finally have found it. Thanks!
Trevor Morgan
August 26, 2021 at 8:46 pmSame issue here. Looking to make the 15:00min countdown timer… But in AE 2021 the expression isn’t working.
Any tips?
Walter Soyka
August 26, 2021 at 9:50 pmAe updated its Javascript engine a few releases ago, and that came with stricter enforcement of curly braces around blocks in if/else statements.
Here’s the code above, updated for recent releases of Ae:
rate = -1;
clockStart = 900;
function padZero(n) {
if (n < 10)
return "0" + n;
else {
return "" + n;
clockTime = Math.max(clockStart + rate * (time - inPoint), 0);
min = Math.floor((t % 3600) / 60);
sec = Math.floor(t % 60);
Chip Hess
August 31, 2021 at 3:38 pmThis is great. Now if we would want to change the duration to something less or greater than 15 minutes, what would we change? Just the Comp length?
Walter Soyka
August 31, 2021 at 4:02 pmChange the clockStart variable, which determines the starting point for the countdown timer in seconds. 900 seconds = 15 minutes * 60 seconds/minute.
If you wanted a 5 minute countdown, you could do this:
clockStart = 5 * 60;
