Activity › Forums › Adobe After Effects › How to create 3D audio visualizer that's like this?
  • Robert Müller
    January 29, 2021 at 9:39 am
    You could do this:
    Create a solid, apply the Audio Spectrum or Waveform effect, make sure start and endpoints are to the very left and very right of the layer, then apply a CC Cylinder effect. It remains a 2D layer but will interact with cameras and you got 3D controlls inside the effect
  • Kristhian Aguilar
    January 29, 2021 at 1:09 pm
    That did the trick, thank you! Now I’ve just gotta make the triangles move up and down to the beat and I’m done
  • Robert Müller
    January 29, 2021 at 1:39 pm
    You can extract keyframe values from the audiochannels and use the now generated slider values to drive the position of your triangles, using a linear function. You should smooth the audio values out though, see this:
    https://www.youtube.com/watch?v=HkkSL2gupRw
    For example, this is what I quickly put together:
    the 36 is the max value for the song I used, this might be different for you. I used the layername as the last parameter, so Ive got a quickly interchangeable variable, to have some variation in this
    s=thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider"); //my null with the audio-keyframe-data
    y=linear(s,0,36,0,thisLayer.name)
    value-[0,y];
