Activity Forums Apple Final Cut Pro Legacy How to create 14:9 footage from 16:9?
  • How to create 14:9 footage from 16:9?
    Posted by Dan Brazil on July 25, 2005 at 7:54 pm
    Can anyone please clear up a few confusions I’m having regarding the creation of PAL 14:9 footage from an original aspect of 16:9? I understand that 14:9 is a compromise between 4:3 and 16:9 so that one can get the best of both worlds. Indeed this is the reason I have been asked to produce a DVD in such a format so that wide-screeners and 4:3ers can both experience the optimum visual experience. I also understand that 14:9 requires the addition of black banding to the sides of the footage. However this is where I am having some trouble:
    -Does the 16:9 footage actually have to be cropped to become a different physical width, and if so what should this be (please bear in mind that I am working on footage captured in FCP as 16:9). And if this is a case I take it I need to re-render the footage to match the new resolution?
    -Do I have to add black bands to the top and bottom as well? And if so what’s the best way to do this (using the ‘slug’ in FCP?)
    -Can anyone point me to a template to identify where exactly do draw these lines. I have had a look at the Digital Heaven plug-in for FCP that deals with this but it looks like it only provides title/action safe lines and I am still uncertain where to actually crop the footage.
    -And once in DVDSP should I set it to pan & scan, letterbox, or both?
    There is relatively little out there that I have found that can walk me through this process and some of it is baffling and even contradictory. I have searched the cow vaults and found links to some of the BBC graphics requirements but these seem primarily to deal with the workflow from 4:3 to 14:9
    Any help most appreciated…starting to drive me a little mad I must admit!
    Dan Brazil
    G5 DP 2.5; 4Gig Ram; Blackmagic Decklink Extreme; 23″ Cinema HD Display; Sony HR Trinitron PAL monitor with SD card; 500 Gig Lacie Big Disk Triple Interface; FCP HD; DVDSP3; After Effects 6.5; Photoshop CS; Illustrator CS; plus many others
    Dan Brazil replied 21 years, 1 month ago 2 Members · 3 Replies
  • Duncan Craig
    July 25, 2005 at 10:55 pm
    Hi Dan,
    14:9 is a 4:3 format, but with a letterbox.
    It exactly half the resize of a 16:9 crop.
    In other words, if you take a 16:9 clip and drop it into a 4:3 sequence, you’d have a 16:9 letterboxed image. To size it up to full screen you would size it up to 133% (rounded up). if you size up half as much ie 117% you’ll have a 14:9 letterbox. But 14:9 has to exist within a 4:3 raster, as DVD players only understand 16:9 and 4:3.
    So you would size up your image, encode it 4:3, and set DVDSP to 4:3. That’s it.
    Of course the best thing would be to encode a disc with both a 14:6 LB and 16:9 FH (Full Height).
    Add a menu where the viewer can choose which type to view, personally I would just put a 16:9FH version on, and stuff the people watching no 4:3. You don’t want black bars at the sides of the picture, that would make it even smaller on a 4:3 screen, if the DVD player was set to 16:9 output. If you have 16:9 originated material, make a 16:9 disc don’t compromise for 4:3 screens.
    I honestly never deliver anything in 14:9 LB, only 16:9 FH – 14:9 protected. What does that mean…Text safe in 14:9 protected is around 30% horizontal (as opposed to 20% in 4:3), so text which is safe in 16:9 may well not be safe in 14:9. All UK TV programmes are currently produced 16:9 anamorphic FH, 14:9 safe, as many people including me only have 4:3 sets at home. The 14:9 squash and sizeup is generally added during transmission, some Sky satellite channels (Men and Motors for example), transmit from 4:3 (14:9LB) masters, which have been ARCed (Aspect Ratio Converted) from 16:9 masters. Of course the source material has to shot with the 14:9 resize in mind, (known as 14:9 shoot and protect).
    A few other points, it worth adding a tiny crop to the top and bottom (0.5 in the motion tab) of the 16:9 image which you drop into a 4:3 sequence, to get rid of the half scan lines at the top and bottom of the image. You may or may get these depend on the format you filmed on.
    And I don’t have a 16:9 TV at home because the picture quality of all 16:9 100Hz sets I have ever seen can’t hold a candle to my 5 year old 29” 50Hz 4:3 Sony Trinitron. 😉
    Cheers Duncan.
  • Dan Brazil
    July 27, 2005 at 8:04 pm
    Duncan,
    Many thanks for your detailed response – it has proved to be most helpful and I now feel I have a stronger grip on the issues I (and my client) are facing. Its one thing trying to understand a theory but when you put it into practice it really makes alot of sense…by this I mean that I have just made some 16:9 material 4:3 and I now realise how its done – you HAVE to scale up – and man does it look crappy….can’t believe that’s what you’ve goyt to do if you want to make true 4:3 out of 16:9. And it all has to be re-rendered! (FWIW I also found thsi link which has proved invluable in getting my head fully around it https://www.amcro.co.uk/widescr.htm )
    But basically this issue all arises because my client doesn’t want to see any bars at all on the DVD and he is also very concerned that the majority of his viewers will be watching on 4:3 TVs and they will not be having an optimum viewing experience if the footage is 16:9. One can argue the point why the project was shot initially in 16:9 in the first place but this is my situation. Would you argue that my client shouldn’t be so concerned about people watching 16:9 footage on 4:3 TVs (they can after all adjust the aspect ratio on most DVD setup menus I guess) or are his fears genuine ones that run across the board?
    Once again, many thanks for your help.
    Dan Brazil
  • Dan Brazil
    July 28, 2005 at 2:51 pm
    So I’ve just had a really stressful/confusing converstaion with the technical guy in the edit suite who has been producing the footage for my client. I was discussing the process by which I achieved the 4:3 version (ie dropping the 16:9 footage into a 4:3 sequence and scaling up to 133%) and he is convinced I am barking up the wrong tree and that I can do it without losing any quality. Everything seemed to be making sense but now I’m baffled once more…
    Here’s what he says.
    The footage was originally put together in After Effects in a 1024×576 widescreen composition with square pixels. He says that if he was making a 4:3 version of the footage he would simply take that composition and drop it into a 4:3 composition and it would fit the HEIGHT perfectly but it would be the width that would be lost on either end. He would then render it out and all would be nice and pristine. And here’s where I am baffled…on the one hand when I implement your method and I drop the 16:9 into FCP I clearly see the WIDTH being the same menaing that I have to scale up. So why do I think the width is the same and he says its the height that’s the same. Is it beacuse I’m working in rectangular pixels and he’s composed in square (but TV’s use recantagular any way). Or is it because when I am using FCP my screen sizes are 720×576 regardless of whether its 16:9 or 4:3…should I change my screen size to a custom size in sqare pixels perhaps. I mean what choice do I have when I capture off a digi-beta and I am told its been recorded in 16:9 anamorphic?
    Please put me out of this madness…
    Dan
