Activity › Forums › Adobe After Effects Expressions › How to cover the whole Composite with scale property?
  • How to cover the whole Composite with scale property?
    Posted by John Kevien on May 3, 2008 at 4:57 pm
    the subject as the title!!
    I am going to moving a small solid layer to left upper corner,and then scale it up to cover the whole composite.
    So, I need some advices.
    Thanks in advance!!
    Dan Ebberts replied 18 years, 5 months ago 2 Members · 1 Reply
  • Dan Ebberts
    May 3, 2008 at 7:35 pm
    This should get you close:
    startScale = 1; //time when scaling starts (seconds)
    scaleDur = 2; // scale duratation (seconds)
    initScale = [100,100]; // initial scale value
    w = thisComp.width*thisComp.pixelAspect;
    h = thisComp.height;
    finalScale = [w/(width*source.pixelAspect),h/height]*100
    ease(time,startScale,startScale+scaleDur,initScale,finalScale)
    If you’re doing this from the upper-left corner, you’ll probably want to move the anchor point to the upper left corner of your layer.
    Dan
