Activity Forums VEGAS Pro How to copy protected ?
  • How to copy protected ?
    Posted by Bernard Ageeb on June 27, 2005 at 8:25 pm
    I have Sony DVD Architect 3. I have projects i would like to copy protect so no one can copy my dvd. How do i do it in DVDA3?Thanks in Advance. Bernard
    Dennis Vogel replied 21 years, 1 month ago 5 Members · 5 Replies
  • Edward Troxel
    June 27, 2005 at 8:30 pm
    You set the proper copy protection flags, send the output to DLT, and then ship that off to a DVD replication facility. You did want 1000 copys, right?
    You can’t copy protect “burned” DVDs.
    Edward Troxel
    JETDV Scripts
  • Gary Kleiner
    June 27, 2005 at 8:31 pm
    You can set a copy protection flag in DVDA 3, but this only enables a replication facility to actually add the copy protection. There’s no copy protection that you can apply when you burn discs on your drive, and there’s no copy protection at all that cannot be easily defeated.
    Sad, but true.
    Gary Kleiner
    Vegas Training and Tools.com
  • Bernard Ageeb
    June 27, 2005 at 8:39 pm
    Thanks guys…to bad i really thought it could be done in dvd3 with my pioneer burner ..oh well.
    Bernard
  • Terje A. bergesen
    June 29, 2005 at 3:07 am
    As has been pointed out in this thread, you can’t do it with your DVD burner. I also am not sure of the value of this. If someone wants to copy your DVD they can do that easily enough whether you copy protect it or not. It will only take an extra few minutes. With the software out there, it is basically a one-click process, and the software is free.
  • Dennis Vogel
    August 12, 2005 at 2:51 am
    Indeed. All copy protection mechanisms only protect against direct digital-to-digital copies. If someone desperately wanted to copy your DVD all they would need to do is play it and capture the image with a capture card or box. Sure, it will be lower quality but it may be good enough for what they want.
    Good luck.
    Dennis
