Activity Forums Apple Final Cut Pro Legacy How to copy and paste text attribute?
  • How to copy and paste text attribute?
    Posted by Newton Niu on January 5, 2010 at 7:08 am
    Hi, everyone!
    I’ve finished doing all the text for my video, but now I want to change their sizes and positions.
    I think it is possible that i change one of them, and then paste attributes to others.
    But how to do that? When i click command C and option V to another test clip, there are several choices such as motion, speed, but none of them seems work.
    How to do that, please, guys?
    Thank you.
    Fredrik Johnson replied 16 years, 8 months ago 4 Members · 6 Replies
  • Shane Ross
    January 5, 2010 at 7:45 am
    Can’t. I wish you could, but no go.
    Shane
  • Newton Niu
    January 5, 2010 at 1:55 pm
    So i have to change all the sizes from 15 to 20 one by one?? God, there are hundreds of them…. Why don’t they do something to improve this?
  • Shane Ross
    January 5, 2010 at 5:14 pm
    [Newton Niu] “So i have to change all the sizes from 15 to 20 one by one?? “
    Yes…
    [Newton Niu] “Why don’t they do something to improve this?”
    Ask them to:
    https://www.apple.com/feedback/finalcutpro.html
    Shane
  • Newton Niu
    January 6, 2010 at 4:40 am
    Thank you, Shane….. but sorry to hear that answer.
  • Ricky Yu
    January 8, 2010 at 6:03 am
    Export an XML
    OPen it with a text editor
    Use the Find Command to find the name of your Text Eg.
    Replace with your desired font Eg.
    Hit replace all
    For Font size it’s a bit trickier, since the size is only indicated by a number and you don’t want to change other numbers that are related to your font size. You have to Copy and paste surrounding lines of code, basically a big chunk that indicates the font size. Replace it with the same big chunk of code but with a different font size value. I can’t get into detail about it here. you just gotta study the code a bit and understand what makes it tick. The same logic applies with the font style I pointed out above.
    Import the XML back into Final Cut to see the result. I recommend doing a test first with only one hunk of text so you don’t get confused.
    RKKY of Hong Kong
  • Fredrik Johnson
    January 8, 2010 at 11:10 am
    As stated above. I would export the XML and do a find and replace for the whole document.
    What you are looking for is something like this:
    (I had to change all the <> to [ ] in my example, since the forum interprets this as html :-))
    [parameterid][fontsize[/parameterid]
    [name]Size[/name]
    [valuemin]0[/valuemin]
    [valuemax]1000
