Activity Forums Adobe Premiere Pro How to copy and paste clip selections using IN and Out points
  • How to copy and paste clip selections using IN and Out points
    Posted by Paul Nevison on October 19, 2012 at 12:07 am
    Hey there
    just switched to PP Cs6 this week..liking it so far…
    Have a question regarding copy and pasting clip selections
    Is there a way to copy and paste sections of clips on a sequence using IN and OUT while preserving the source track ie not using lift/extract?
    I normally make a “master” timeline with all my interview footage, then I make a selects timeline, and to get those selects, I’d like to copy and paste between IN and OUT points without extracting the material (like the lift). That way I can still have my full “master” timeline to refer to.
    thanks
    Ann Bens replied 13 years, 11 months ago 4 Members · 5 Replies
  • Angelo Lorenzo
    October 19, 2012 at 7:17 am
    Set your in and out point in your timeline as normal. You can use lift (shortcut 😉 and then undo (command+z or control+z). Since the lifted portion will remain on your clipboard, you can go to your other sequence and paste.
    Not quite as intuitive as you’d think, but it works and it’s only an extra keystroke.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Ann Bens
    October 19, 2012 at 12:46 pm
    You can also Alt+drag the clip from one sequence to another sequence.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Chris Tompkins
    October 19, 2012 at 10:19 pm
    Can you alt drag that beer over here please?
    Chris Tompkins
    Video Atlanta LLC
  • Paul Nevison
    October 19, 2012 at 11:19 pm
    Thanks so much for the tip!!
    Macpro Dual core 3Ghz
    8GB RAM
    OS 10.6.4
    QT 7.6.6
    FCP 7.0.3
    AE CS4
    BMD Decklink HD Extreme 6.6
    PAL Land
  • Ann Bens
    October 20, 2012 at 7:54 pm
    Chris: i knew this would get your attention 😉
