Activity › Forums › Apple Final Cut Pro Legacy › how to convert wvm into QT
Posted by Juliett on March 6, 2006 at 11:00 amHi everyone
I have a few WMV files that I need to import into my FCP project.
What’s the best way of doing this.
Regards
Julie
Craig Seeman replied 20 years, 6 months ago 3 Members · 3 Replies -
Jerry Hofmann
March 6, 2006 at 2:18 pmhttps://www.flip4mac.com sells software for working with these files…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Juliett
March 6, 2006 at 4:24 pmHi I used Flip for Mac to view these files. Then
I have just exported the WMV file to a qt movie using Quick Time Conversion
I changed the setting in the options tab.Video Settings Compression Type DV PAL. Size 720 by 576. Frame Rate 25. Audio Linear PCM. Sample Rate 48kHz.
Although this altered the frame size the frame rate wasn’t converted to 25. It still stayed as 29.97.
Any idea why this may be?
Julie
Craig Seeman
March 6, 2006 at 8:04 pmJulie,
I just opened a NTSC WMV in Quicktime Pro 7.0.4. I used Export Movie to QuickTime Movie. Compression DV-PAL. Frame Rate 25 fps. Size Custom Width 720, Height 576 and it worked. It wasn’t pretty though. Shouldn’t really be any different in FCP though. Make sure you’ve changed frame rate to 25fps and not Current.
