Activity Forums Apple Final Cut Pro Legacy How to convert to .mjpg
  • How to convert to .mjpg
    Posted by Jeff Michaels on December 4, 2009 at 1:07 am
    My client is asking me to provide the final video in the .mjpg format. Can you please tell me what program for mac will allow me to convert a .mov to a .mjpg file? I have done some online research but have come up short since this seems to be a pretty obscure file format. I appreciate the help.
    Rafael Amador replied 16 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
  • Michael Gissing
    December 4, 2009 at 1:40 am
    Motion jpeg is a codec and .mov is just a wrapper.
    Exporting from FCP using quicktime conversion will create a motion jpeg .mov file if you select that codec. You could try renaming the file using the .mjpg extension if it still doesn’t work.
  • Pasi Koivisto
    December 4, 2009 at 1:46 am
    The codec is called Motion JPEG A/B in QuickTime, if you can’t see that codec in Video Settings of QuickTime you need to enable “Show Legacy encoders” in the quicktime advanced preferences.
  • Rafael Amador
    December 4, 2009 at 4:11 am
    “.mjpg” it doesn’t exist.
    “.mpg” yes.
    To be requested today a Motion JPEG is not much norma.
    To be requested an .mpg is very normal.
    Are you sure is not an “.mpg” what your client want?
    I think that somebody put the”j” by mistake.
    rafael
    http://www.nagavideo.com
  • Jeff Michaels
    December 4, 2009 at 10:54 pm
    Thanks for the response. So is there no file extension called .mjpg? Are you saying it’s only a codec? The client wants the video to play in one of those video picture frames and she says they only take .mjpg files which I believe are files from digital cameras.
  • Rafael Amador
    December 6, 2009 at 4:22 pm
    Hi Jeff,
    I found an “.mjpg” extension.
    Is for a Motion-JPG for PCs (IBM).
    There is nothing in Mac that works with such a extension.
    rafael
  • Jeff Michaels
    December 7, 2009 at 2:37 pm
    Rafael,
    Do you know of a program that will convert a file to .mjpg? It’s ok if it’s a PC program. Thanks
  • Luke Pearson
    December 7, 2009 at 6:26 pm
    Might be worth exporting to Motion JPEG in QuickTime and just changing the extension from .mov to .mjpg to see if that works.
  • Rafael Amador
    December 8, 2009 at 2:46 am
    Hi Jeff,
    As luke suggest, try changing the extension to .mov, or without extension.
    The codecis just a Motion-JPEG. Is very possible that works.
    You may try with MPEGStreamcip.
    rafael
