Activity › Forums › Adobe After Effects › How to convert properly?
Posted by Richard Smith on December 28, 2010 at 8:15 pmThis question is only partially related to AE.
I have a MKV file my AE won’t load. I’ve been advised to convert it to MOV. But someone said converting one format into another always results in (minor) quality loss.
Is this true?
If it is, how do professionals do it?
I imagine they, too, sometimes have to convert files.Todd Kopriva replied 15 years, 9 months ago 3 Members · 7 Replies -
Amit Zinman
December 28, 2010 at 9:40 pmMKV is a lossy type of MPEG-2 as far as I know.
But you would have to “open” the frames anyhow to do anything with them. You would be served well with converting to Quicktime Animation or Photo-JPEG. -
Todd Kopriva
December 28, 2010 at 10:00 pm> But someone said converting one format into another always results in (minor) quality loss.
Is this true?Not precisely true.
Each time that you compress a movie using a lossy codec, you lose some quality. However, there are many lossless codecs, and you can compress with those with no loss in quality. Amit mentioned one such codec: Animation.
Personally, I use the PNG video codec in a QuickTime (MOV) container when I want a losslessly encoded/compressed movie. It’s about 50% better at saving file size, but it’s also a little more processor-intensive.
Other folks use Lagarith and some other codecs that don’t come with the standard QuickTime installation.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Richard Smith
December 29, 2010 at 7:53 am[Todd Kopriva] “I use the PNG video codec in a QuickTime (MOV) container”
Can this be done in Windows, with AE?
[Todd Kopriva] “losslessly encoded”
Is it really lossless? You don’t lose any quality?
Todd Kopriva
December 29, 2010 at 8:11 am> Can this be done in Windows, with AE?
Yes.
Yes, it’s really lossless. No, you don’t lose any quality.
The lossless codecs are good for archiving and for using in intermediate stages of a post-production workflow, but they aren’t good for playback or streaming or other final distribution.
Todd Kopriva
December 29, 2010 at 8:24 amBack to your original question, though—After Effects doesn’t open MKV files. So, you have to convert them using something else to even get them into After Effects.
Yes, After Effects can losslessly encode movies after you’ve imported your source files into it, but you still have to clear that first hurdle.
There are other software packages that can convert MKV files. I can’t recommend any specifically, though. Just make sure that you use a lossless codec for the output when doing the conversion.
The real solution for next time is to not use MKV format to start with, if you can help it.
Richard Smith
December 29, 2010 at 8:46 am[Todd Kopriva] “you have to convert them using something else to even get them into After Effects.”
Yes. I mean to convert the file via Total Video Converter. And as I don’t want quality loss to occur, I’ll use your suggestion- Quicktime Animation codec.
I selected MOV as converted filetype but.. in the Codecs list there is no mention whatsoever of any Animation codec.
Where can I find it? -
Todd Kopriva
December 29, 2010 at 5:01 pmHere’s a page that gives some information about enabling the “legacy” QuickTime codecs:
https://kb2.adobe.com/cps/403/kb403333.html———————————————————————————————————
