Activity › Forums › Apple Final Cut Pro Legacy › how to convert MP3 to FCP friendly import
Posted by Kent Beeson on December 8, 2007 at 5:06 pmHello
Buying some MP3 royalty free music and I need to import into FCP Studio 1..what’s the best way to do this? Does it have to be converted into aiff or will FCP do it automatically?
KB
Dmitry Chulkov replied 11 years, 4 months ago 5 Members · 10 Replies -
Tom Wolsky
December 8, 2007 at 5:08 pmYes, it should be converted to AIFF at the correct sample rate. There are bunches of different ways to do this, Compressor, the QT player, iTunes, or using FCP and batch export.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
Kent Beeson
December 8, 2007 at 5:12 pmThanks for reply…so how would I do this using FCP and export? I need to import into FCP…Would I import the MP3 into FCP browser then what? Or is iTunes easier – if so what’s the procedure? I take it I need to make the tracks into 48 aiff not 44?
Thanks KB
Tom Wolsky
December 8, 2007 at 5:18 pmTo use FCP import the files. Use batch export. Set the destination. Set the export settings and do it.
All the best,
Tom
Kent Beeson
December 8, 2007 at 5:37 pmI just did the conversion and I have a couple of ?’s…when I chose aiff from drop down menu (using batch export) it asked me for a different name which I gave it but it left it as mp3..then the second time I redid this, I typed in .aiff in place of the mp3 file extension and when it was done it came out as aifc(?) It does import into FCP fine, but what’s going on with the aifc and why did I have to type in aiff when it should have automatically gave it this file extension?
KB
Chris Poisson
December 8, 2007 at 6:06 pmMost of the time QT Pro is what I use, but there’s also a really neat little audio app called Switch, which does everything really fast and well.
Have a wonderful day.
Kent Beeson
December 8, 2007 at 6:44 pmThanks for your workflow – but if I can do it in FCP why would I need/want to do it in any other app be it QT pro or Switch? Is there a quality difference?
KB
Chris Poisson
December 8, 2007 at 8:13 pmKent,
FCP is an editor. The other tools were designed for manipulating media. It doesn’t really matter, except that tying up FCP to convert files is a huge waste of horsepower.
Dmitry Chulkov
May 19, 2015 at 5:49 amuse this tool for cutting mp3 https://inettools.net/en/application/cutmp3
it is free and easy
