Activity Forums VEGAS Pro How to convert Interlaced footage to progressive
  • How to convert Interlaced footage to progressive
    Posted by Bernie Ageeb on February 1, 2011 at 3:26 am
    Hi All,
    I am using the trail Red Giants instant HD. It says your footage has to be progress, so i need to know what is the best way to convert my sd interlaced clip to progressive? Can it be done in vegas 10? Thanks in advance
    Bernie
    John Rofrano replied 15 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    February 1, 2011 at 12:38 pm
    [Bernie Ageeb] ” i need to know what is the best way to convert my sd interlaced clip to progressive? Can it be done in vegas 10?”
    You will need to render it to a progressive format and possibly lose some quality unless you render to a lossless format like uncompressed, Lararith, or Huffyuv. I would use Boris FX UpRez instead. It doesn’t require progressive footage and so there is no loss in quality like InstantHD.
    To render progressive, select a render format that is close to your original source or a lossless format, press the Custom… button and change the Field Order to None (progressive scan). Then render.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
