Activity Forums Apple Final Cut Pro Legacy How to convert .fcp to .xml without using Final Cut Pro
  • How to convert .fcp to .xml without using Final Cut Pro
    Posted by Clint Nitkiewicz hernandez on August 6, 2012 at 8:30 pm
    My Final Cut Pro 7 project opens in FCP 7, however, whenever I click on anything within the project, any of the menus, or try shortcuts, I get the spinning wheel, therefore I cannot export a .xml.
    I want to convert my .fcp project file into .xml, to try to use with 7tox to fcpx or premiere cs6 to continue the project.
    Starting over in a program is not an option, I really need to convert the .fcp file to .xml so I can use another program to continue it.
    Is there a workaround for this?
    Thanks.
    Clint Nitkiewicz Hernandez
    https://www.imdb.com/title/tt1427924/
    Director
    Butch Vz replied 13 years, 6 months ago 2 Members · 1 Reply
  • Butch Vz
    February 28, 2013 at 11:43 pm
    Did you have any luck finding a workaround? I also have an FCP file that I’d like to open in Premiere Pro CS6. It would be nice to accomplish this without the aid of a Final Cut using friend.
