Activity › Forums › Maxon Cinema 4D › How to convert cube into a mograph object?
  • How to convert cube into a mograph object?
    Posted by Al-reyan Ansari on February 12, 2012 at 4:55 pm
    Hello Everyone,
    I am trying to figure out how to convert a cube into mograph object?
    I want to make buildings that will grow from origin to top. I can make it with squash and stretch but I want the particles to come from random directions to make building grow. I have seen mograph text tutorials how they make the text reveal and I want to do same with a cube. If anyone know how to do that then please please let me know. Its for my major project which is due next week. Thanks in anticipation.
    Greg Burrus replied 14 years, 7 months ago 2 Members · 1 Reply
  • Greg Burrus
    February 14, 2012 at 5:02 am
    If your talking about a building “like(simple)” structure that is just made with cubes. You could just use a cloner set to object mode then using a simple building model you could tell it to use the shape of the buildings, vertex points, surface, etc… and have then have the cubes form that shape. Then using effectors you could have it build on in any way you like.
    If your talking about a more complex object you may want to look into building it with thinking particles. You might be able to use a fracture object to break it apart and then build it together too. Or you could try the polygon unfolding technique.
    There are a number a way to go about it you may be able to show it falling apart and then in either c4d or after effects time remap it and reverse it. The voxel preset & particle dissolve look good for that. Although time remapping in c4d can be a pain some times
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
