how to convert avi to uncompressed 4:4:4
Hi everyone,
i’m working on a low-budget movie, but along the way i notice i’m really lacking some knowledge about how to approach this project.
We made a feature with 8 and 16 mm film, but it will be shown on 35 mm.
They digitalized everything by making a bmp picture of each frame and put it in a avi-container. But no the framerate is 62,7 Mb/sec, which is way to high for FCP.
Someone on a forum tolled me this:You should create an uncompressed 4:4:4 master from the original image sequence, edit offline at a lower resolution, conform the uncompressed master to the offline EDL and use that to print to 35 mm.
I’ve asked him if he could explain it to me a bit more detailed, but i think he has no time.
So could someone explain me,How do i convert to uncompressed 4:4:4, because i only seem to have 4:2:2 in my converter?
Does it matter if it’s 8-bit or 10-bit?
Once i have it converted, is changing you timeline settings to offline RT enough?Thanks, Rob
