Activity › Forums › Compression Techniques › How to convert an image sequence to a PNG encoded MOV with alpha channel
  • How to convert an image sequence to a PNG encoded MOV with alpha channel
    Posted by Uli Kilian on February 24, 2012 at 3:52 pm
    Hi Guys,
    I’ve searched the whole web and RTFM but couldn’t find an answer to the simple question:
    How can I convert an image sequence with an alpha channel (eg TGA) to a MOV file using the PNG codec while preserving alpha channel.
    I know this is possible because I can export such a MOV out of other software. But I need ffmpeg to do it.
    Again:
    What I have:
    32bit TGA files including alpha channel
    What I want:
    A lossless but as small as possible Quicktime file which includes the alpha channel
    What I was able to achieve:
    A MOV file holding raw uncompressed data including alpha channel. But that is sometimes 10 times bigger than the (lossless) compressed PNG codec in Quicktime. So I really need it to be smaller. I would be also happy with some other lossless (but compressed) alternative.
    What I used to achieve the uncompressed huge MOV file:
    ffmpeg.exe -r 30 -i C:\temp\test_%04d.tga -y -r 30 -vcodec rawvideo -pix_fmt rgba test.mov
    ffmpeg version N-37208-g01fcbdf Copyright (c) 2000-2012 the FFmpeg developers
    built on Jan 27 2012 18:34:52 with gcc 4.6.2
    configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enab
    le-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
    able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --en
    able-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
    libxvid --enable-zlib
    libavutil 51. 34.101 / 51. 34.101
    libavcodec 53. 60.100 / 53. 60.100
    libavformat 53. 31.100 / 53. 31.100
    libavdevice 53. 4.100 / 53. 4.100
    libavfilter 2. 60.100 / 2. 60.100
    libswscale 2. 1.100 / 2. 1.100
    libswresample 0. 6.100 / 0. 6.100
    libpostproc 52. 0.100 / 52. 0.100
    Input #0, image2, from 'C:\temp\test\nounderscore%04d.tga':
    Duration: 00:00:01.03, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: targa, bgra, 1920x1080, 30 tbr, 30 tbn, 30 tbc
    [buffer @ 01E39C80] w:1920 h:1080 pixfmt:bgra tb:1/1000000 sar:0/1 sws_param:
    [buffersink @ 03C302C0] auto-inserting filter 'auto-inserted scale 0' between the filter 'src' and the filter 'out'
    [scale @ 03C311E0] w:1920 h:1080 fmt:bgra -> w:1920 h:1080 fmt:rgba flags:0x4
    Output #0, mov, to 'nounderscore.mov':
    Metadata:
    encoder : Lavf53.31.100
    Stream #0:0: Video: rawvideo (RGBA / 0x41424752), rgba, 1920x1080, q=2-31, 200 kb/s, 30 tbn, 30 tbc
    Stream mapping:
    Stream #0:0 -> #0:0 (targa -> rawvideo)
    Press [q] to stop, [?] for help
    frame= 31 fps= 19 q=0.0 Lsize= 251101kB time=00:00:01.03 bitrate=1990663.1kbits/s
    video:251100kB audio:0kB global headers:0kB muxing overhead 0.000325%
    But when I change “-vcode rawvideo” to “-vcode png” it drops the alpha channel alltogether.
    I played around with
    -pix_fmt rgba
    -pix_fmt argb
    -pix_fmt bgra
    -pix_fmt abgr
    but nothing worked…
    On the web there are different solutions but nothing worked for me. It seems my ffmpeg version (which is a fairly new build) doesn’t support it because other people claimed they did it by using exactly the same command.
    Are there any other suggested builds?
    Or am I missing something here?
    Any help is very much appreciated indeed.
    Uli
    Samuel Were replied 13 years, 10 months ago 4 Members · 4 Replies
  • Reuben Martin
    February 25, 2012 at 2:59 am
    It should work. You might try specifying the input pix_fmt option in front of the -i option to ensure that 32bit mode is enforced.
    You can also try the “qtrle” codec which is basically quicktime animation codec. It supports alpha.
  • Uli Kilian
    February 27, 2012 at 7:15 pm
    Reuben – Thanks a lot!
    The qtrle option works. Finally I can encode with alpha channel.
    Thanks for sharing!
    However – as the PNG compression is a bit more efficient it would be nice to get that encoded with ffmpeg.
    If anyone has any idea – please share.
    I tried to put the “-pix_fmt argb” option in front of the -i option – but didn’t make any difference. Nor did all the others (abgr, rgba, etc).
    Anyway.
    Thanks again, Reuben!
    Uli
  • Tatiana Solano
    April 23, 2012 at 5:35 pm
    Hello
    I have been working with ffmpeg an a gif animation, so I was trying to do a video from it with alpha channel, and finally with your coments I figure it out, I use a sequence of png images that get from the gif animation and use the next code:
    ffmpeg -i homer%05d.png -vcodec png -pix_fmt rgb32 -y z.mov
    And it works… Hope it helps you
  • Samuel Were
    November 1, 2012 at 3:26 pm
    It doesn’t work for me 🙁
    I have mov png with alpha on input and I would like scaled down with alpa on output.
    Everything works OK except output mov has no alpha.
    Please help!
