Activity › Forums › RE:Vision Effects › How to convert 30i to 24p with twixtor 4.5 pro? I’ve been searching forever..
  • How to convert 30i to 24p with twixtor 4.5 pro? I’ve been searching forever..
    Posted by Carlos Crooks on March 19, 2008 at 10:46 pm
    Hey guys,
    I’ve read that twixtor 4.5 pro can convert my 30i video to 24p. How is this done? Can someone help me please? I’ve been searching and searching, but can’t find the answer.
    Thanks.
    Pierre Jasmin replied 18 years, 6 months ago 2 Members · 3 Replies
  • Pierre Jasmin
    March 19, 2008 at 11:45 pm
    If in AE for example (it varies per host)
    1) Set Compositon Settings to 24 FPS
    2) Drop true 30i footage in new comp (by true I mean not a 3:2 pulldown thing)
    3) Set Input Fields usually to lower for 30i and set Input Frame Rate to 30
    4) Render at 24P
    Pierre
    https://revisionfx.com/products/twixtor/support/
  • Carlos Crooks
    March 19, 2008 at 11:53 pm
    Thank you very much for the fast reply. I really do appreciate it, but i have one last question.
    In Twixtor 4.5 pro, i don’t see the Output frame rate control that everyone is saying to put 24p into and have the input at 30. Why aren’t I seeing that in my effects window for the plug in?
    If you need a screen shot ill post one to show you what Im talking about.
    And will my audio match up if i convert it to 24p?
    Thanks again
  • Pierre Jasmin
    March 19, 2008 at 11:58 pm
    It was like that in version 3
    Now we use the FrameRate value in the Composition Settings as output frame rate
    search “Frame Rate” in html doc that comes with it
    Pierre
