Activity › Forums › Apple Final Cut Pro Legacy › How to convert 24p to 29.97 ASAP!
  • How to convert 24p to 29.97 ASAP!
    Posted by Evelyn Carrigan on July 19, 2005 at 9:30 pm
    I’ve taken over a project for someone who shot a commercial in 24p on miniDV. I diged it at 24p. The footage plays back fine in FCP, but not on my monitor – I only see a static shot when I pause the playhead. I need to convert this, I’m assuming, to 29.97 in order to output to Beta (for tomorrow July 20th!). How do I do this?
    Thank you for any help you can provide,
    Evelyn Carrigan
    Video Production/Post Production
    The Allen|Roche Group
    12 Farnsworth
    Boston, MA 02210
    Office: 617.422.0003
    Mobile: 617.784.3636
    ecarrigan@allenrochegroup.com
    Evelyn Carrigan replied 21 years, 2 months ago 4 Members · 10 Replies
  • 10 Replies
  • David Jones
    July 19, 2005 at 11:18 pm
    Re-digitize it at 29.97
  • Graeme Nattress
    July 20, 2005 at 2:26 am
    Make sure your timeline is at 23.98fps. Plug in your DV deck and play it out. There’s a timeline preference to add 3:2 pulldown to the output to take it to 29.97fps.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Jeremy Garchow
    What are your system specs?
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Evelyn Carrigan
    July 20, 2005 at 10:43 am
    Do you know where I can find that? Thanks for your help.
    Evelyn Carrigan
    http://www.reelblonde.com
  • Evelyn Carrigan
    July 20, 2005 at 10:47 am
    The editor before me diged at 30fps and there’s a sync problem. Have you done this before – if so, did you change your settings in the timeline, or anywhere else? Thanks for your help, David – my client is coming in at noon today! Yikes.
    Evelyn Carrigan
  • Evelyn Carrigan
    July 20, 2005 at 11:11 am
    Hi Graeme,
    I just found an article about the process of digitizing 24p video and 48kh sound.
    https://www.editorsguild.com/newsletter/MayJun04/mayjun04_23-24_proj.htm
    What this article states is exactly what you were saying – with 23.976 your audio doesn’t have to make an adjustment of 1%. When pulling in at 24p there is a delay in the video of 2 frames, so the solutions are either to find an audio delay option and set it for 1-5 frames OR pull in your audio analog so that it is true 48kh. Hope this makes sense!
    Evelyn Carrigan
  • Evelyn Carrigan
    July 20, 2005 at 11:19 am
    Hi Graeme,
    Evelyn Carrigan
  • Graeme Nattress
    July 20, 2005 at 1:11 pm
    Your source tapes are 24p right? Are the 24p normal or 24p advanced? Either way, when capturing you must set FCP to nromal DV NTSC at 29.97fps. You can’t just capture at 24p and hope it will work, because it will not. Do you know which setting was used on the camera??
    https://www.kenstone.net/fcp_homepage/24p_in_FCP_nattress.html
    Should explain a lot.
    Graeme
  • Evelyn Carrigan
    July 21, 2005 at 9:19 pm
    Hi Graeme,
    HELP! I’m going to lose this client because FCP 5 still won’t play my video correctly. I did what you said – captured at 29.97, all settings normal NTSC DV 48khz. The video is markedly slower even without listening to the audio. You can see how it lags.
    I actually recaptured the video onto my internal HD to see if that made a difference, but it didn’t – thought maybe it was a communication/bus problem to my Lacie drive.
    I’m not sure if the video was shot 24p advanced or normal, but I went ahead and removed the “advanced pulldown” from a clip just to try it. It syncs up nicely, but the video plays back quickly as though it’s been intentionally altered to look sped up.
    Also, when I originally captured at 24p I was able to use the Apple audio delay filter to sync the clips up pretty darn closely. Unfortunately, the filters have corrupted the video and made them play back like there’s a trail whenever you see movement.
    This computer is 2.5 GHz with 1.5 GB Ram – brand new G5 dual processor. It crashes at least 3 times a day when I’m in FCP. It’s doing weird things.
    Graeme, thank you for any help you can provide.
    Evelyn
    Evelyn Carrigan
  • Evelyn Carrigan
    July 21, 2005 at 9:20 pm
    G5 Power MAC 2.5 GHz dual processor 1.5 GB RAM
    Evelyn Carrigan
