Activity › Forums › Adobe After Effects › how to control duplication layer with slider control in after effects
  • how to control duplication layer with slider control in after effects
    Posted by Suniel Surya on August 5, 2016 at 4:41 pm
    Hi Guys !!
    I’m Working With Simple 3D Project.. i’m Creating A 3D Box Layer… with this script ( value + [0,0,index] )
    but i want to control layer duplication with Slider Control is it Possible
    even i increase the value in slider control then layers will automatically duplicate based the value … is it possible friends
    P.Surya Suniel
    Editor,Siticable
    Admin,www.tutofactory.com
    Michael Szalapski replied 10 years, 1 month ago 2 Members · 1 Reply
  • Michael Szalapski
    August 5, 2016 at 7:50 pm
    You couldn’t control the number of layers with a slider, but you could control the opacity of a bunch of duplicates with a slider to achieve a similar result.
    The opacity expression you’d need to create would be significantly longer than the one you’re currently using for position!
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
