Activity Forums Maxon Cinema 4D How to connect spring to two object?
  • How to connect spring to two object?
    Posted by Carl Allinson on March 16, 2023 at 4:58 pm
    Hi all,
    I’ve been having a play in C4D, creating the Pixar lamp. The design has springs and I’m wanting to know how to connect the spring to two objects that work with an IK rig.
    I tried using Xpresso to connect the spring helix height to the objects position, which works; however when i use the controller for the IK rig, it decides not to.
    I have the spring dynamics activated and it allows me to target object A and B and the preview works like a charm. Is there a way to use that preview information to apply to my spring?
    Carl Allinson replied 3 years, 5 months ago 2 Members · 3 Replies
  • Michael blaq
    March 16, 2023 at 10:14 pm
    Hi Carl,
    Can you attached a sample scene?
  • Carl Allinson
    March 17, 2023 at 12:38 pm
    Hi Michael,
    I have attached the c4d project file.
  • Carl Allinson
    March 17, 2023 at 2:32 pm
    Hi Michael,
    I have figured it out.
    Firstly, I converted the helix into a null and made that the parent of the helix.
    I then did the same for Bolt A and B, but made these the child of the objects.
    I opened Xpresso, added the bolts and the helix and did the following in the screenshot. Once this was done, I applied a constraint tag to the Helix Null and ticked “Transform”. In the Transform tab I made sure PRS were all turned on and I targeted this to Bolt A.
    On the helix I applied another constraint tag, but this time ticked “Aim” and targeted Bolt B.
    Its now working just like the spring dynamic.
