Activity › Forums › Maxon Cinema 4D › How to connect polygons extruded from Illustrator spline
  • How to connect polygons extruded from Illustrator spline
    Posted by Jamison Whatley on August 5, 2008 at 10:09 am
    Hello all,
    I have brought in an illustrator spline of an outline of an astronaut. It is kind of hard to explain but my goal is to create a rounded surface of the front of the astronaut and use the actual reference photo as a texture material to cover it so that it is more 3 dimensional looking than the actual astronaut photo. I only need the front half of the astronaut to be showing.
    I put the spline in an extrude nurb and am using a fillet cap for the front. The front is still flatter than I would like so I thought if I could scale the cap small and move it outward while stretching the rounding of the fillet as well this would give me the curved surface I was looking for. But I can’t get the cap to to connect to the rounding of the fillet and when I go to scale it it scales as a separate piece and the fillet rounding doesn’t move.
    How do I fix this or alternately is there an easier way to do this? I’m a graphic artist by trade and this will be used for a lenticular poster. I don’t have any experience with 3D modeling so this is new to me and was kind of just thrown in my lap.
    Using C4D v. 10 I believe.
    Here are a few pics to kinda help explain things.
    original spline:
    https://i37.tinypic.com/907pn8.png
    extruded spline:
    https://i36.tinypic.com/235hd1.png
    detached cap:
    https://i37.tinypic.com/2ikfc40.png
    Jamison Whatley replied 18 years, 1 month ago 2 Members · 3 Replies
  • Adam Trachtenberg
    August 5, 2008 at 10:00 pm
    After you convert the extrudeNURBS to polys you need to select all the resulting objects and run the Functions>Connect command. Then run the Function>Optimize command on the object you just created. That should weld everything together for you.
  • Jamison Whatley
    August 6, 2008 at 6:07 am
    Tried that and it doesn’t work. It makes a new extrude nurbs object. Tried scaling/moving the cap and it is still not attached to the rest and scales/moves separately. Tried it on both the original and the new extrude nurbs object.
    https://i38.tinypic.com/2iid56g.png
  • Jamison Whatley
    August 6, 2008 at 7:52 am
    Got it to work, something was amiss with the original spline. Resaved it out of illy and it worked. Thanks for your help.
    Unfortunately it looked like crap the way I had planned to make it. I guess I will bring in the spline as a template and just construct the rounded convex front part using other splines in c4d.
