Activity › Forums › Maxon Cinema 4D › how to connect Extruded text polygone all together
  • how to connect Extruded text polygone all together
    Posted by Sheng Huang on April 16, 2010 at 4:28 am
    I have came to a problem that when i Extruded text and made it editable, i connected the caps and body, after that, when i select one polygon at the edge between the cap and body, it splited. how to connet all the Extruded element together at one time?
    Randy Johnson replied 16 years, 5 months ago 2 Members · 1 Reply
  • Randy Johnson
    April 16, 2010 at 5:56 am
    In the object manager select both the body and the caps and right click then select CONNECT from the drop menu.
    You may need to while in point mode run an optimize command But only if you are using a hyper nurbvs.
    /randy
