Activity Forums Apple Final Cut Pro Legacy How to Compress TV/VIDEO NOISE without Artifacts??
  • How to Compress TV/VIDEO NOISE without Artifacts??
    Posted by Jbertain on August 1, 2007 at 6:33 pm
    I’m running FCP5 on a Dual PowerMac G5 (2.5 RAM).
    My little predicament is that in my film the use of physical video/tv noise is a key part. Seeing the actual noise on screen is essential. The only problem I am seeing is when I compress, using compressor or just FCP every clip directly after the tv noise is pixelated and has “blocking artifacts”. It ruins the quality of the film.
    I’ve read somewhere in a forum that TV noise is like ‘poison’ to mpeg. Any ideas on how to export/compress?
    Thanks.
    Jon
    Rafael Amador replied 18 years, 9 months ago 6 Members · 17 Replies
  • 17 Replies
  • Russell Lasson
    August 1, 2007 at 6:43 pm
    So you shot a TV with a camera and now your compressing it? What codec are you editing in?
    -Russ
  • Jbertain
    August 1, 2007 at 6:46 pm
    I’m editing in Final Cut 5 and I have tried several different combinations of compressing. But I’ve been using Compressor, compressing it as Mpeg2.
  • Russell Lasson
    August 1, 2007 at 6:58 pm
    What camera did you shoot it on? Is it HD?
    -Russ
  • Jbertain
    August 1, 2007 at 7:02 pm
    Oh sorry,…The clips are mini dv. It is DV/DVCPRO – NTSC, and it’s 720 x 480.
  • Jbertain
    August 1, 2007 at 7:03 pm
    I shot it on a SD camera. The whole project is SD, not HD.
  • Russell Lasson
    August 1, 2007 at 7:12 pm
    It’s an uphill battle when you shoot on DV to make a great looking MPEG2 file, but you might try applying a 4:1:1 Color Smoothing filter (in the Key folder of Video Filters) before you compress the section. That should help cut down the artifacts.
    Also, compression is more of an art than a setting. In your case, it will turn into an experiment. Try making several custom settings in compressor and seeing how each setting effects this section of your film. Play around with the advanced settings too (even if you don’t know exactly what they do).
    Also, if you export a self contained movie file and open it in QuickTime, it won’t look good until you enable high-quality video for the clip in the QuickTime settings. (Apple+J – select video track – select visual settings – select high-quality video in lower right of the box.)
    -Russ
  • Jbertain
    August 1, 2007 at 7:23 pm
    Great, thanks. I’m trying it now. So then with DV what is the best way to compress it, being I have FCP and Compressor?
    Do I export: quicktime movie self contained or not self contained? Then should I take that file and drag into compressor or just straight into DVDSP, and is Mpeg2 the best format for a DV project? Or is there some way to “up-press” the quality?
    I know it’s a lot of quations, I do apologize. I am versed more in art than tech specifics, but I’m coming to realize they must *equally* compliment each other. Again thanks for your help thus far.
    j
  • Ben Holmes
    August 1, 2007 at 7:26 pm
    Have you tried encoding using the 2-Pass Variable bit rate? This should analyse the video and check for these kind of ‘tricky’ encoding moments.
    However, I suspect you’ll still struggle. MPEG2 does indeed hate noise, as do many other long-gop formats, and even MJPEG. If this is so important to your project, and DVD is the final output format, you may have consider a way around this. A different transition could help (via black?) or you could try lowering the video levels. Sometimes this helps compression if the differences between light and dark areas in lowered.
    Professional DVD transfers require many passes and often frame by frame analysis to avoid problems like this – compressor is a bit of a blunt instrument in comparison. You could always try another product, like Media Cleaner – but I cannot speak from any experience if this will help.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live broadcast.
    OB Server 1 HD – Mobile FCP editing done right.
    https://www.editecuk.com/OBServer2.html
  • Russell Lasson
    August 1, 2007 at 7:34 pm
    Exporting the file to compressor instead of using DVDSP is better. It gives you more options.
    Exporting a self-contained file at current settings then taking that file to compressor is the same as sending it directly from FCP to compressor.
    If you have applied filters to the section of your film, then you might want to change the sequence settings to DV50 or Uncompressed. If the clips don’t need to be rendered, then that won’t help in getting the quality to be a little better.
    -Russ
  • Russell Lasson
    August 1, 2007 at 7:35 pm
    Also if you want to get really tricky, you might try to blur the blue channel a little as noise is often strongest in the blue channel.
    -Russ
