Activity Forums Compression Techniques How to Compress DigiBeta for Web
  • How to Compress DigiBeta for Web
    Posted by Christian Clark on July 26, 2010 at 1:51 am
    I just spent an hour or so looking on the Cow and on the web for a clear answer to this:
    How do I compress DigiBeta for the web? Does 720×486 become 640×486 or should I crop six pixels and then compress at 640×480? Is there a standard answer or is it up to me?
    Christian H. Clark
    City Limit Films
    http://www.citylimitfilms.com
    Chris Blair replied 16 years, 1 month ago 2 Members · 1 Reply
  • Chris Blair
    July 28, 2010 at 1:14 am
    You’ll want to adjust the size so it’s 4:3 with square pixels since a 720×486 image will look stretched on computer screens, but beyond that it’s up to you and dependent on how fast your viewers’ internet connection is.
    With H264 nowadays, you can easily get away with 512×384 and it will stream on most decent speed internet connections. You can even get away with 640×480, although that will likely bog down on anything below a cable modem.
    We typically stick with 512×384 or 480×360 or 432×324. You also need to consider the web player you’ll be using…meaning Flash, Quicktime etc. If you use Flash, you’ll get better results keeping your sizes as multiples of 16 or at the very least 8.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
    Read our blog http://www.videomi.com/blog
