How to compress AIC to H264 without the jumpy and ghosting footage
Hello,
I recently upgraded from a Canon HV40 to a Canon XF100 and switched from a tape based work flow to a Compact Flash based work flow. I transferred the files to FCP just fine, edited the project, and found that the best way to export the footage from FCP was by using the Apple Intermediate Codec. The resulting MOV file looked exactly like the footage in FCP, but of course hadn’t been compressed very much.
Now I have an AIC MOV file that will not upload to Youtube, because it is an intermediate video file and not a file ready for upload.
My question is how do I compress this AIC MOV file to H264 format for the web without having the jumpy footage and ghosting effect during the motion shots?
Also, does this have to do with interlaced or progressive footage?
When I was using the 1440×1080 HV40 footage in the past I exported a Final Cut Pro Movie file from FCP, pulled it into Compressor, and compressed to H264 from there. I didn’t do that this time, because I was working with true HD footage and not HDV. Should I do that this time?
My Final Cut Pro sequence settings are:
Frame Size: 1920×1080
Vid Rate: 29.97 fps
Field Dominance: Upper (Odd)
Pixel Aspect: SquareI’ll provide any other information that can be useful.
Jake Williams
