Activity Forums Adobe Premiere Pro How to compensate for colour changes within a clip.
  • How to compensate for colour changes within a clip.
    Posted by Corinne Friesen on June 4, 2019 at 7:04 am
    I’ve been googling this but not getting anywhere helpful.
    I have a clip recorded under coloured lights that were supposed to stay steady. I discovered, after the fact, that the lights changed colour according to the intensity of the vocals. Ugh.
    How can I correct for this in Premier or After Effects?
    Corinne Friesen replied 7 years, 3 months ago 3 Members · 4 Replies
  • Jon Doughtie
    June 4, 2019 at 10:14 am
    Any chance of a reshoot? That would be the best solution.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Kalleheikki Kannisto
    June 4, 2019 at 2:21 pm
    Depending on the speed of change. If it is rapid, Re:Vision De:Flicker does a decent job evening out fast variations. If is is slower, not much you can do, other than manually adjusting it with luma curves. There’s a Color Stabilizer effect in AE, but I find it often adds as much new problems as it corrects.
    I just recalled that Chris Wright made an “Auto White balance” template. I haven’t tested it myself but you should give it a try. See here: https://forums.adobe.com/thread/2108848
    Senior Graphic Designer
  • Corinne Friesen
    June 4, 2019 at 7:19 pm
    Thank you, Kalleheikki, I’ll give that a try.
    Corinne
  • Corinne Friesen
    June 4, 2019 at 7:21 pm
    Thank you, Jon. I’m going to try not to resort to that, since the clip was, otherwise, exactly on target. But, that solution is always waiting in the wings. :/
