Activity Forums Cinematography how to compare lights
  • how to compare lights
    Posted by Gerardo Flores on June 25, 2011 at 6:18 pm
    There is any possibility to compare continuos lighting with photographic ligths
    I got some of this lights
    https://www.bhphotovideo.com/c/product/50346-REG/Speedotron_22218_M90Q_UV_Lamphead.html
    and I thinking to get some continuos light Ep. but the only point of reference that I have are this speedotron lights … It is the same amount of lights from the same 1200w sources???
    i mean the light I get on the arri 1200W in the maximum will be the same as I get from
    the speedotron???
    any ideas????
    some led light use the LUX as a units to know the amount of lights that the equipment produce…
    how can I know how many LUX this arri or speedotron lights produce???
    Best regrards
    learning after effects
    Alan Lloyd replied 15 years, 2 months ago 2 Members · 1 Reply
  • Alan Lloyd
    July 1, 2011 at 1:42 pm
    Strobes and continuous lights do not compare directly, for one reason. Strobes put out a very large amount of light for a very short time. Unless you could find a strobe that would synchronize exactly with your camera’s frame rate (and not induce seizures in anyone in the room) there just is no direct comparison.
