Activity › Forums › Adobe After Effects › how to combine several masks (on one layer) into a single mask? AE7
  • how to combine several masks (on one layer) into a single mask? AE7
    Posted by David Lieberman on March 9, 2007 at 11:42 am
    hya everyone.
    just wanted to know if its at all possible to combine a number of masks to create one mask. What im trying to do is take the word LOVE (for example) which is split onto 4 masks (L/O/V/E) and add the waveform effect. the problem is that it asks for a mask, and i cant choose all the masks at once.
    When i add the same effect 4 times, only one masked effect can be seen at any given time…
    so is there any way to take all 4 masks and combine them? or if not, is there a way to import the word (thru illustrator maybe) as a single mask?
    thanks a lot for the help.
    shroomly.
    David Bignell replied 15 years, 6 months ago 5 Members · 4 Replies
  • Tony Kloiber
    March 9, 2007 at 2:22 pm
    Not sure how the waveform effect works but you could split the masks out to four layers.
    Take the layer you have now, add the effect to the L mask, get the settings as you like, rename this layer L, duplicate the layer three times, name the next layer O and change the mask that the waveform effect uses to the O mask, and so on down the line.
    If you like you could parent and link the effect controls of the O,V,E layers to the L layer so that you only need to change one layer to control them all.
    TonyTony
  • Mylenium
    March 9, 2007 at 3:52 pm
    [shroomly] “so is there any way to take all 4 masks and combine them?”
    No. This is AE, not Illustrator. ;O) Like Tony said, split the letters to separate layers.
    Mylenium
    [Pour Myl
  • Sam Moulton
    March 10, 2007 at 9:44 pm
    you can’t combine LOVE in Illustrator either. You’d end up with one mask for L, V, and E and 2 for O…
    I’d suggest that you adjust the kerning so that the letters overlap, then auto trace them to create a new mask and use that.
  • David Bignell
    March 11, 2011 at 6:36 am
    Combining masks from the same layer into one mask.
    Method – combing path data from both masks and turning them into a single position path
    that is recombined into a single mask.
    1. make a very small solid layer in your comp.
    2. first mask – click onto words ‘mask path’
    edit/copy
    3. be on frame 0 – on your very small solid layer goto position and paste.
    a new position path in the shape of your first mask appears.
    4. 2nd mask – click on words ‘mask path’
    edit copy
    5. goto a few frames past the last keyframe of the newly created position path on your
    very small solid layer then goto position and paste.
    a new position path in the shape of your second mask appears – it should already be linked
    to the first position path
    6. click on position path and edit/copy
    7. on same layer as your original paths that you are combining make a single point mask.
    8. click on ‘mask path’ and paste. This is your combined mask.
