Activity Forums Adobe After Effects How to combine “Card transition effect” with “radial wipe” ?
  • How to combine “Card transition effect” with “radial wipe” ?
    Posted by Michele Busiello on May 15, 2011 at 4:34 pm
    Hi!
    the result i want to achieve is hard to explain. i give my best 🙂
    here is the problem: i want to make a circle dissapear in pieces, clockwise in a “radial transition” fascion (like a 360° hand fan https://alturl.com/xisvc is it possible to somehow combine the “card transition” effect with a radial wipe ? I know i could do this by hand..but it would be too much work!
    Kevin Camp replied 15 years, 4 months ago 3 Members · 3 Replies
  • Jason Mettler
    May 15, 2011 at 4:52 pm
    Can you make as many comps of the circle as you want ‘pieces’ and then apply the radial wipe to a static percent (such as 15%,20%, etc)on each layer and then just sequence them to run one after the other until the circle is gone?
  • Michele Busiello
    May 15, 2011 at 4:53 pm
    thanks for your quick reply..but your solution comes very close to “do it manually” 😉
  • Kevin Camp
    May 15, 2011 at 10:03 pm
    Card wipe can use a 2nd layer as a gradient map, and the gradient map can be used to determine flip order. So I think you can create a comp that does the radial wipe that you want, then used that radial wipe comp as the gradient map for card wipe.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
