Activity › Forums › Adobe After Effects Expressions › How to combine 2 expressions under Source Text
  • How to combine 2 expressions under Source Text
    Posted by Frederic Beaulieu on February 18, 2021 at 1:03 am
    I would like to create an expression that when applied to Source Text, allow me to repeat a word horizontaly and verticaly and also uses slider expressions to animate the font size, leading and tracking.
    So this is the styling part:
    txt = text.sourceText;
    var z = effect("Size")("Slider");
    var l = effect("Leading")("Slider");
    var t = effect("Tracking")("Slider");
    createStyle().setFontSize(z).setAutoLeading(false).setLeading(l).setTracking(t).setText(txt);
    And this is the repeating part:
    xRepeater = effect("xRepeat")("Slider").value;
    yRepeater = effect("yRepeat")("Slider").value;
    horzRepeat = txt.repeat(xRepeater);
    vertRepeat = horzRepeat + "\n";
    vertRepeat.repeat(yRepeater);
    Both work independently, i’m just scratching my head about how to combine them.
    Dan Ebberts
    replied 1 year, 7 months ago
    3 Members · 4 Replies
  • Dan Ebberts
    February 18, 2021 at 7:20 am
    Something like this should work:
    xRepeater = effect("xRepeat")("Slider");
    yRepeater = effect("yRepeat")("Slider");
    repeatTxt = vertRepeat.repeat(yRepeater);
    createStyle().setFontSize(z).setAutoLeading(false).setLeading(l).setTracking(t).setText(repeatTxt);
  • Frederic Beaulieu
    February 18, 2021 at 2:36 pm
    Wonderful! Thanks for your precious help! Merci beaucoup!
  • Mårten Gunge
    February 4, 2025 at 10:46 am
    Hi. I have a somewhat similar problem. I am trying to make a “money counter”. A slider goes from 30 to 1500. The problem is that the client has really rigid typo-rules. Needs to be a very specific space between 1 and 000 when the slider hits 1000. I´ve made this little snippet. Problem is that the styling seems to disable the input from the slider, so there is no animation, only static sourcetext.
    text=effect("Slider Control")("Slider")+" dollarez”;
    if (effect("Slider Control")("Slider") > 999) {
    style.setTracking(180, 0, 1)
    else
    {style.setTracking(0);};
    Tried to fix it with sourceRectAtTime, but no luck. Guess that´s part of the problem; need knowledge, not luck. Please enlighten me!
  • Dan Ebberts
    February 4, 2025 at 5:02 pm
    This should work:
    txt = effect("Slider Control")("Slider") + " dollarez";
    style.setText(txt).setTracking(180, 0, 1)
    }else{
    style.setText(txt).setTracking(0);
