Activity › Forums › Adobe After Effects › How to colorize hue for stroke on text differently to the fill?
  • How to colorize hue for stroke on text differently to the fill?
    Posted by Jack Package on October 24, 2014 at 11:05 am
    Hi everyone
    I’m trying to achieve an effect on a text layer where the fill of a text has the colorized hue effect on, say, red, and the stroke of the same text layer a different color, say, yellow, and then keyframe the colorize hue setting so that it changes over time, like a rainbow effect, so to speak.
    But if I apply hue/saturation to the layer and colorize the hue, all colors in the layer become red or yellow.
    What do I do?
    John Cuevas replied 11 years, 11 months ago 3 Members · 2 Replies
  • James Archibald
    October 24, 2014 at 11:32 am
    Hi Jack,
    You can animate the hue values of your stroke and fill independently using the Animate tools found to the right of the ‘Text’ field in your text layer’s properties.
    Click the > arrow next to Animate and choose either ‘stroke color’ or ‘fill color’ depending on which you’d like to animate.
    • Archie •
  • John Cuevas
    October 24, 2014 at 11:43 am
    Twirl open your text, add a text animator for Color Fill. Another method would be to duplicate your layers, set one to fill only, one to stroke only then add your effect to only the fill layer.
    Check out this example project: 8135_fillstrokecolor.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
