Activity › Forums › Adobe After Effects › How to color correct/remove too much light from part of a frame
  • How to color correct/remove too much light from part of a frame
    Posted by Marcie Maute on January 9, 2012 at 11:44 pm
    Hey All,
    I am working on a film right now and I am stumped. Here is my issue, the clip I was given was very poorly lit on production, the key light is obviously a key light. Ideally I would like to remove/diffuse/color correct so that it is not so noticeable. I have avid, FCP, and AE at my disposal, I just don’t know which one can do the job – or if its even possible!
    I tried to Limit Effect Color Correct in FCP and couldn’t get a change. I thought about cloning the normal looking areas in order to replace the extremely lit ones, however the DP moves the camera in a very odd way which would make tracking difficult.
    Any help appreciated! THanks
    heres a still…
    Marcie Maute replied 14 years, 8 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    January 10, 2012 at 4:32 am
    If the area isn’t completely clipped you might try to make an adjustment layer with the proper color settings and roto it out manually.
  • Walter Soyka
    January 12, 2012 at 1:52 am
    If at least one of the RGB channels isn’t clipped, you’d be able to mitigate that blown-out key light by copying it to the clipped channels to recover a little detail.
    Walter Soyka
  • Marcie Maute
    January 12, 2012 at 2:02 am
    Thats exactly what I have been attempting to do, it takes forever. But at least I have been able to isolate certain areas in order to manually color correct them.
    What do you mean by clipped?
    thanks for your help!
