Activity › Forums › Apple Final Cut Pro Legacy › how to clean video shot with +6dB gain?
Posted by Mariusz on October 3, 2005 at 3:03 amHi,
I have part of video that was shot +6dB for practical reasons. It does not match very well to different video that was shot at 0dB.
Do you guys have any solution or any plugin that would help to clean up image litlle bit? Can I export it as stills to Photoshop maybe and there is tool that would help? Any help would be appreciated.
I am using FCP 5 of course 🙂Keith Mann replied 20 years, 11 months ago 9 Members · 11 Replies -
David Roth weiss
October 3, 2005 at 5:31 amMariusz,
Unfortunately the old adage, “garbage in, garbage out,” applies in your situation. What’s on tape is the best you’ve got. Your only option is to go the other direction, i.e. to mess up the other stuff to match. Most people never take that route though for obvious reasons.
DRW
Max Frank
October 3, 2005 at 5:59 amBoris Continuum has a ‘de-noise’ filter, that kind of smooths the shot out somewhat – give it the illusion of being ‘clean’.
It doesn’t work for every situation, but has helped me on a number of occassionss.
Good luck,
Wayne
Mark Suszko
October 3, 2005 at 6:51 amYou might try compositing an identical layer that has had some gaussian blur applied, then see what blending between the two at various amounts will do. Might also try playing with the gamma settings. These are just guesses, based on what I’d try to do with a single still image. In FCP, under Compositing drop-down menu, you find a bunch of built-in modes to try. I would go for “guess-and-press”, with about 99 levels of undo;-)
Hey, what’s the worst that could happen? It doesn’t work, and you revert.
Hans Vernhout
October 3, 2005 at 9:06 amIf you happen to have Adobe After Effects 6.5 in your toolbox as well you could try the Remove Grain effect on your 6 dB footage.
Hans Vernhout
Director / lighting cameraman
The Netherlands -
Kurt Hennrich
October 3, 2005 at 10:30 amyou may try my plugin ‘deGrain’
which is part of my 1z1Tools I am just releasing.
see: https://www.1z1.at/plugins/the text there is still ragged because of my bad english – sorry, will be fixed soon.
you can download demo and try if it helps with your shot:
the satisfaction will depend on the movements in the shot.good luck,
kurt -
Walter Biscardi
October 3, 2005 at 11:07 amI would look at the 3 Way Color Corrector. Crush the blacks, probably by -10 or so to start with and then manipulate it from there. Crushing the blacks straight off will reduce some visible noise. If you can get the colors close, then you may be able to get the noise cleaned up a bit more by using some noise reduction filters.
One other thing to do depending on what the project is, is to make the shot black and white to make it look like you’re doing an effect with that shot.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
G5 Dual 2.0, AJA Kona 2, Medea FCR2X
Mariusz
October 3, 2005 at 12:19 pmWalter,
What noise reduction filters you had in mind?
I do not have AE or Boris Continuum mentioned above unfortunately. I do have a Photoshop , FCP 5 Studio, SketchUp and Keynote. That together would be all my pro applications. Can I use these tools to somehow reduce a grain?
I will try crushing blacks, maybe go for b/w and I will try Kurt’s deGrain filter later today. Thanks a lot for all replies.Mariusz
Walter Biscardi
October 3, 2005 at 12:22 pmFCP doesn’t have a great noise reduction filter, in fact I’m not sure it even has one. You would want a third party filter to really help out, but even there, it’s not going to be great with a shot at +6db.
