Activity Forums Adobe Premiere Pro how To choose Yellow or Red Trim tool
  • how To choose Yellow or Red Trim tool
    Posted by Steve Alterman on August 12, 2013 at 4:52 am
    I know this should be so basic. (I’m coming from FCP).
    I can’t seem to control when I get the yellow(ripple trim) or red trim tool. I have “R” set as kb shortcut for Ripple and “Shift+R” for Roll, but I can’t seem to choose between the Yellow (ripple delete) or Red (Ripple w/o delete..
    It seems to arbitrarily happen.
    Thanks much.
    Steve
    Steve Alterman replied 13 years ago 2 Members · 2 Replies
  • Roel Bus
    August 12, 2013 at 1:00 pm
    Steve,
    If you go to “preferences – trim” you can check the “allow selection tool…without modifier keys”. It makes for much faster trimming and working overall. Then if you are using the selection key: when you are on a cut, the tool changes to the “roll”, and just before or after the cut it changes to the “ripple” (yellow arrow). If you want the “trim” (red arrow), which will leave a gap, hold down the command key when the arrow is yellow, and it will turn into a red one.
    I have found this to speed up my editing dramatically. You then don’t need to use the shortcut keys for ripple or roll.
  • Steve Alterman
    August 12, 2013 at 5:38 pm
    That helps so much.
    Thank you.
    Steve
